I know this is an old thread, but I thought I'd add my two cents. I used a free vector graphics program called Inkscape (which can also read AI files) to create my own svg symbol font and then used a free online font converter to convert it to TTF. It worked pretty well!
Here is a tutorial on making fonts in Inkscape:
Make a dingbat font with Inkscape | Clever Someday
I found that the symbol editor in ArcMap didn't quite get me the look I wanted for any symbols with layers. There were often alignment problems. My next step was to convert the symbols into a cartographic representation. Cartographic representations are much easier to refine. They looked great.
I'm finding now that I want to add more symbols to my Representations and would like to directly import vector graphics from Inkscape. Anyone know if there is a way to do that?
Hello Laura,
I'm attempting the same thing as Carrie; can't get 'Labels' or 'Symbology' to do what I want to do.
All I need to do is create a multi-layered icon and position accurately. Complex icon is as follows, from background upwards - Grey circle; White Circle; Icon.
Am now using a paid for FontCreator to create a font which then ArcGIS can read.
- Tried importing as font and allocating in 'Labels', but as you say offsetting and no access to creating a complex icon by adding circles behind.
- Tried creating a complex icon in FontCreator and ArcGIS doesn't recognise it and only sees a black circle.
Please can you link to Cartographic Representations?
- Is there an issue with using Cartographic Representations, in that only you can view/not shareable?
- Did you manage to get around this issue, anyone?
Many thanks,
Caroline
Hi Caroline,
Cartographic representations are stored in the gdb, so there shouldn't be an issue as far as viewing. I think you may also be able to export as a layer.
I basically created a font that I would have to layer once I got into ArcMap. In my example above the circle, arrows and text are all different characters in the font. I created them using a multi-layer symbol and then converted them to cartographic representations, where I further refined them.
I would suggest that you create the multi layer symbol in Symbol Property Editor and then convert it to a representation.
In this example, I used two simple symbols to create the circles and then my custom font to create the character marker symbol in the center. From there, I would convert the symbols to a representation (right click on the layer in ArcMap).
Representation Editor Screen:
Notice how the symbols are a bit off-centre and mis-aligned.
Here is the finished symbol in the Representation Editor:
That's great Laura, thank you for replying.
Yes, have a font too and classification in attributes to make this work, so can copy the method.
- How did you get on with placement/overlapping Representation Markers?
Now, they are not in 'Labels', we can't use positioning labels/hierarchy with each cluster of icons.
- Do we need to just use a definition query and write another attribute field in the dataset?
ie. Priority field
etc?
Any help appreciated.
Many thanks,Caroline
