From what I can tell the new NearMe widget is not working either in AGOL or in the Developers Edition 2.0 with the Tab Theme. Thanks for your help.
-Stan
OK I found that it only happens when the NearMe widget is loaded in the side panel in the Tab theme. Lucky me, right where I need it. Also customer support told me it is a known issue for that theme and will be fixed someday.
Not sure what the repercussions are but I did this and it works so far:
I commented out the lines that say:
dijit.byId(this.domNode.parentElement.id).resize();
in [App#]\Widgets\NearMe\Widget.js line 668
and
dijit.byId(this.parentDiv.id).resize();
in [App#]\Widget\NearMe\item-list.js lines 178, 185, 449, 530, 573, 652, 814 and 891
The error says that resize is undefined so I got rid of it. It would be better to just define it but I don't know how to do that.
So far with this method it does not report the correct feature count after the identify.
Hi Stan,
Thanks for reporting to the group.
I wanted to let you know that we fixed this in the July 2016 Release of Web Appbuilder for ArcGIS, and Web Appbuilder Developer Edition 2.1.
-Lindsay
