Is there still this limitation with labels in 1500? I have a shape file containing street names which are attached to short invisible line segments. I can't seem to find where you would turn on labels and then set the source of the text string to pull from the appropriate field...J
Is there still this limitation with labels in 1500? I have a shape file containing street names which are attached to short invisible line segments. I can't seem to find where you would turn on labels and then set the source of the text string to pull from the appropriate field...Thanks all.J
Rob,To use an Annotation Feature Class you'll first need to create a Layer file (.lyr) for it in ArcGIS Desktop - we don't support adding it directly from a Geodatabase.Another option for quickly labelling content whilst in the application is the Feature Labeller Add-in on ArcGIS.com: http://www.arcgis.com/home/item.html?id=856431c3611b4ffa847938906a5ea43d. CheersMike
Hi,You'll need to set up the labelling in ArcMap then create a Layer File / Layer Package and add that to ArcGIS Explorer. Alternatively you try annotation feature classes.RegardsMike
Wow nearly 2016 and still no labeling function in ArcGIS explorer. The OP was from 2010.
Still no labeling in ArcGIS explorer ...
