I am trying to figure out how I would go about do basic CRUD on a feature service table using esri/request in 4.x and any example code would be greatly appreciated.
Hi, I do not have the code handy however you will need to use the rest add-feature endpoint
I imagine it will be something like the following. Note code below are untested
You can also open your developer tool in chrome and hit the addfeature endpoint, set f=json to see exactly how you should be parsing the request and replicate that in esriRequest.
https://developers.arcgis.com/rest/services-reference/add-features.htm
var data = [ { "geometry" : {"x" : -118.15, "y" : 33.80}, "attributes" : { "OWNER" : "Joe Smith", "VALUE" : 94820.37, "APPROVED" : true, "LASTUPDATE" : 1227663551096 } }, { "geometry" : { "x" : -118.37, "y" : 34.086 }, "attributes" : { "OWNER" : "John Doe", "VALUE" : 17325.90, "APPROVED" : false, "LASTUPDATE" : 1227628579430 } }]
var url = "https://abc/ArcGIS/rest/services/xyz//FeatureServer/0/addFeature "
esriRequest(, { responseType: "json",
method:"post",
body:JSON.stringify(data)}).then(function(response){ });
