Yup, 'vi' is your friend.They never got the marking capability running on the arcgis.com Forums.- V
Do you have an escape character in the Unix mapping file? If it was edited on Windowsit may be missing a terminal newline (or have embedded CR before the LF).- V
Do not attempt to load into the AREA and LEN shape properties. If you use 'sdetable -o describe'you'll see the column layout that 'shp2sde' sees; this should help.The types are all equivalent, so you only need 'shpname sdename' in the mapping file. Don'tmention the shape column in the mapping file (-l table,COLUMN handles that).- V
