I have a GUID field in an AGOL feature layer that I can not get to appear in the attribute table in a web map or under the data tab for the feature layer, when I say I can't get it to appear I mean it is not available as a field when I go to "Add/Remove Columns". The field does however show when I open the feature layer in ArcGIS Pro and the field shows in the pop-up in the web map. I need to use the field in a join in AGOL but I am at a loss as to why I can see it. Any thoughts on how to remedy this would be greatly appreciated.
