import sys, os, arcpy from arcpy import env from arcpy.sa import * if arcpy.CheckExtension("Spatial"):    arcpy.CheckOutExtension("Spatial") else:    print "No SA licence"    exit HomeDir = "c:/Path to directory here/" fgdb = "Name of your fgdb.gdb" InData = os.path.join(HomeDir, fgdb) env.workspace = InData env.overwriteOutput = True ListRast = arcpy.ListRasters() for r in ListRast:    print "Processing", r    Ras = arcpy.Raster(r)    NullRas = IsNull(Ras)    NCol = NullRas.width    NRow = NullRas.height    NCell = NCol * NRow    Mean = NullRas.mean    NNull = Mean * NCell    print "{} % Null {}".format(r, NNull / NCell * 100)   Â
Neil
To loop through a raster table you can use.
input = "myIntRaster" cursor = arcpy.da.SearchCursor(input, ['value', 'count']) for row in cursor: Â Â Â Â print (row)
-Steve
If you run IsNull followed by Get Raster Properties with MEAN you will get the mean of the 1 and 0 output from IsNull. Multiply this number by 100 and you have the percentage NoData in the raster.
