portalUser = loggedInUser.toLowerCase();
var portal, portalUrl = document.location.protocol + '//www.arcgis.com'; var portalUser = null; var share; //flag to determine whether the application is shared or not function Init() { esri.config.defaults.io.proxyUrl = "proxy.ashx"; esriConfig.defaults.io.alwaysUseProxy = false; esriConfig.defaults.io.timeout = 180000; // Create the portal portal = new esri.arcgis.Portal(portalUrl); // Set error messages from xml file dojo.xhrGet({ url: "errorMessages.xml", handleAs: "xml", preventCache: true, load: function (xmlResponse) { messages = xmlResponse; if (dojo.isIE < 9 || dojo.isFF <= 3.5 || dojo.isChrome <= 5 || dojo.isOpera <= 9.5 || dojo.isSafari <= 3.1) { alert(messages.getElementsByTagName("browserSupport")[0].childNodes[0].nodeValue); return; } share = GetQuerystring('extent'); if (share != "") { dojo.dom.byId("divTextContainer").style.display = "none"; dojo.dom.byId("divMapContainer").style.display = "none"; ShowProgressIndicator(); portal.signIn().then(function (loggedInUser) { portalUser = loggedInUser; sessionStorage.clear(); FindArcGISGroup(); }); if (dojo.query(".dijitDialogPaneContentArea")[0]) { dojo.query(".dijitDialogPaneContentArea")[0].childNodes[0].innerHTML = "Enter your Username and Password"; } } else { dojo.dom.byId("divTextContainer").style.display = "block"; } var userAgent = window.navigator.userAgent; if ((userAgent.indexOf("iPad") >= 0) || (userAgent.indexOf("Android") >= 0)) { isTablet = true; dojo.dom.byId('dynamicStyleSheet').href = "styles/tablet.css"; } else { isBrowser = true; dojo.dom.byId('dynamicStyleSheet').href = "styles/browser.css"; } dojo.connect(window, 'onresize', function (evt) { setTimeout(function () { CreateScrollbar(dojo.dom.byId('divLayerContainer'), dojo.dom.byId('divLayerContent')); }, 500); if (map) { if (dojo.dom.byId("map").style.display != "none") { dojo.dom.byId('map').style.marginLeft = (dojo['dom-geometry'].getMarginBox("holder").l) + "px"; dojo.dom.byId('divFrozen').style.marginLeft = (dojo['dom-geometry'].getMarginBox("holder").l) + "px"; dojo.dom.byId('showHide').style.right = (dojo['dom-geometry'].getMarginBox("holder").l + 15) + "px"; ToggleContainers(); map.reposition(); map.resize(); ResetSlideControls(); dojo.dom.byId("divTempMap").style.left = ((dojo['dom-geometry'].getMarginBox("mapContainer").w + (dojo['dom-geometry'].getMarginBox("holder").l)) - dojo['dom-geometry'].getMarginBox("divMap").w) + "px"; setTimeout(function () { dojo.dom.byId("divFrozen").style.height = (map.height - 140) + "px"; }, 500); ResizeChartContainer(); } } });
