My JS app (v3.6) has two parts: map and form. Both are in absolutely positioned divs that toggle display. In other words, when the map is visible, the form is set to display = none and when the form is set to display = block, the map is set to display = none.I am finding that if I go to the form page and move my browser from one monitor to another or even change the size of my browser window, when I return to the map page the map is not visible. If I resize the map after returning to the map page, I only see a strip of map vertically in the center of the page and I get 2 error messages in my console that say:Error: Invalid value for <image> attribute x="NaN" svg.js:15Error: Invalid value for <image> attribute y="NaN" svg.js:15How can I refresh the map so that it will show up even if the window size is changed while it is hidden. As far as I can tell, everything works fine if I change the window size while the map is visible.
var map = new Map("mapPane", { autoResize : false, //.....
on(window, 'resize', function() { // prevent map from resizing when not visible. This would error otherwise if ( map is visible ) //pseudo code { map.resize(); map.reposition(); } });
You save my life bro!
Thanks a lot!
