var time = new Date().getTime().toString(); //javascript object with params for the save itself // and arrays for the various geometry types var saveObj = { name: name, description: description, time: time, userId: userId, department, department, project: project, polygons: [], polylines: [], points: [], markers: [], text: [] }; //create json of each polygon object and push it to the polygon array dojo.forEach(app.map.getLayer('gl_anno_polygon').graphics, function (g) { var obj = g.toJson(); saveObj.polygons.push(obj) }); //do the same polylines, points, etc //convert js object to json var save = dojo.toJson(saveObj); //use ajax and some form of RDBMS to save json object //parameters like name, userId, etc are also saved in separate fields in the database entry
{ "geometry": { "rings": [[[-13715131.833534349, 5759372.32022381], [-13714845.194678271, 5759200.336910164], [-13715299.039533727, 5758751.269368976], [-13715514.018675784, 5759042.685539322], [-13715131.833534349, 5759372.32022381]]], "spatialReference": { "wkid": 102100 } }, "attributes": { "id": "1375306164892" }, "symbol": { "color": [0, 115, 197, 51], "outline": { "color": [0, 115, 197, 255], "width": 1.5, "type": "esriSLS", "style": "esriSLSSolid" }, "type": "esriSFS", "style": "esriSFSSolid" }, "infoTemplate": { "title": "Polygon", "content": "<div style=\"line-height:1.5;\"><a style=\"cursor:pointer;text-decoration:none;\" onclick=\"app.anno.editStyle(${id}, 'polygon')\">Edit Polygon Style</a><br /><a style=\"cursor:pointer;text-decoration:none;\" onclick=\"app.anno.bringTop(${id}, 'polygon')\">Bring to Top</a><br /><a style=\"cursor:pointer;text-decoration:none;\" onclick=\"app.anno.sendBottom(${id}, 'polygon')\">Send to Bottom</a><br /><a style=\"cursor:pointer;text-decoration:none;\" onclick=\"app.anno.deleteGraphic(${id}, 'polygon')\">Delete</a></div>" } }
dojo.forEach(loadObj.polygons, function (polygon) { //the polygon param is the json for a single polygon // simply creating a graphic with the json recreates it attributes, symbol and info template var graphic = new esri.Graphic(polygon); //array of all loaded graphics for zooming features.push(graphic); //graphic id to identify polygon to edit, delete, etc graphic.graphic_id = polygon.attributes.id; //set custom objects of the graphic used by custom print task graphic.graphic_atts = polygon.attributes; graphic.graphic_it = polygon.infoTemplate; //is the graphic a text symbol also for printing graphic.graphic_text = false; //add to the annotation polygon layer app.map.getLayer('gl_anno_polygon').add(graphic) });
Do I have to setup a custom arcgis server in production to be able to render map and save data?Do I have to use geodatabase to store the information?
HI Ben,
I know its a old post but i need to do the same. I need to save the drawing (consisting of point , polygon, line , text) into database with user info and retrieve the same when the same user log in.
I have just one question to the solution ..can we use feature service to store the drawings. If your ans is yes can you please provide some input for the same.
