When copying features from file geodatabase to the enterprise geodatabase (using copy & paste), an error that says: The number of points is than required for features. Repair geometry is used before copying. This is shown in the shots below.Regards, Hani
The SE_TOO_FEW_POINTS error (-148) can occur when the integerization of coordinate locations collapses very small polygons or lines -- when using thedefault XYSCALE, an area or length of less than one millimeter. If you increasethe precision (reduce the value), you may be able to retain the polygon, butyou also need to consider whether a feature that can only be seen with amicroscope really belongs in a GIS database.- V
