'This is assuming that the code is executed from the onload event of the identifyform. Dim query, ownername, thedatasource ' form layer datasource, which you need to execute SQL commands thedatasource = ThisEvent.Object.Parent.Datasource 'note the single quotes enclosing the string we're querying against at the end query = "SELECT [OWNERS NAME FIELD] FROM [TABLE RELATED TO PARCELS] WHERE [PRIMARY KEY FIELD] = '" & ThisEvent.Object.Fields("PrimaryKeyField").value & "'" 'returns a recordset object, see the help for other methods you can use. It will only contain the 1 field you queried for above ownername = thedatasource.Execute(query) 'Assign the value you got to the empty editbox you set up. ThisEvent.Object.Pages("Page1").Controls("empty edit box for storing the owners name").value = ownername.Fields("OWNERS NAME FIELD").value
