import arcpy, os arcpy.env.overwriteOutput = True inPts = arcpy.GetParameterAsText(0) inDistance = arcpy.GetParameterAsText(1) outputFolder = r"c:\gpServices\writeToFolder" #this needs a matching entry in the datastore. #If you have the output param set to required, make sure the path/name in the dialog matches the path set inside the script outputFC = os.path.join(outputFolder, r"output.gdb\output2") arcpy.Buffer_analysis(inPts, outputFC, inDistance)
# Import Python Libraries import arcpy, os, string from arcpy import env # Set Overwrite Output Environment env.overwriteOutput = True # Define Output Folder outputFolder = r"E:\arcserver\data\tooldata" # helper method to check if a field exists in a fc def check_for_field(featClass,fieldName): hasField = 0 desc = arcpy.Describe(featClass) fields = desc.fields for field in fields: # check without case as ArcGIS is not case sensitive if field.name.upper() == fieldName: hasField = 1 return hasField # Define inputs # Input ISOCODE fcString = arcpy.GetParameterAsText(0) # Project Data # Input Fishnet fish = outputFolder + os.path.sep + fcString + ".gdb" + os.path.sep + fcString + "_fishnet_full_attributes" # Coordinate System wgs84 = arcpy.SpatialReference(4326) # Describe Fish desc = arcpy.Describe(fish) # Calculate Raster Extent extent = desc.Extent xmin = int(round(extent.XMin - .5)) xmax = int(round(extent.XMax + .5)) ymin = int(round(extent.YMin - .5)) ymax = int(round(extent.YMax + .5)) # Define Gridding Variables gridFieldsWildCard = arcpy.GetParameter(1)#"*TOTPOPBT_2010*M" gridFields = arcpy.ListFields(fish,gridFieldsWildCard) # Lines per degree, determines the output resolution 120 = 30 arc-seconds resolution # 1 degree divided into 120 parts is 30 seconds linespd = 120 ## Update As Needed cellSize = 1.0 / linespd # Output the gridded count rasters for field in gridFields: gridField = field.name arcpy.AddMessage("The field to be gridded is " + gridField) # Output Grids outPopGrid = outputFolder + os.path.sep + fcString + "_grids.gdb" + os.path.sep + fcString + "_" + gridField arcpy.env.extent = arcpy.Extent(xmin,ymin,xmax,ymax) arcpy.env.outputCoordinateSystem = wgs84 arcpy.env.cellSize = cellSize arcpy.AddMessage("The extent is " + str(arcpy.env.extent)) if arcpy.Exists(outPopGrid): arcpy.AddMessage(outPopGrid + " exists") else: try: arcpy.PolygonToRaster_conversion(fish,gridField,outPopGrid,'CELL_CENTER','#',cellSize) arcpy.AddMessage("Created " + outPopGrid) except: arcpy.AddMessage(arcpy.GetMessages())
