For some reason when i try and start and stop an edit session the stop.Editing(True) does not work because it appears that an edit session was never started. See code snippet below:
workspace <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>dirname<SPAN class="punctuation token">(</SPAN>shl_fc<SPAN class="punctuation token">)</SPAN>
edit <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>Editor<SPAN class="punctuation token">(</SPAN>workspace<SPAN class="punctuation token">)</SPAN>
edit<SPAN class="punctuation token">.</SPAN>startEditing<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN>isEditing<SPAN class="punctuation token">)</SPAN>
edit<SPAN class="punctuation token">.</SPAN>startOperation<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Update SHL Geometry</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>UpdateCursor<SPAN class="punctuation token">(</SPAN>shl_fc<SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN>shl_dsu_field_name<SPAN class="punctuation token">,</SPAN>shl_well_num_field_name<SPAN class="punctuation token">,</SPAN><SPAN class="string token">'SHAPE@XY'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> shl_updatecursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> feature <SPAN class="keyword token">in</SPAN> shl_updatecursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">if</SPAN> dsu_name <SPAN class="keyword token">in</SPAN> feature<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">and</SPAN> well_num <SPAN class="keyword token">in</SPAN> feature<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">:</SPAN>
projected_shl_coordinates <SPAN class="operator token">=</SPAN> ProjectCoordinates<SPAN class="punctuation token">(</SPAN>float<SPAN class="punctuation token">(</SPAN>shl_coordinates<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>float<SPAN class="punctuation token">(</SPAN>shl_coordinates<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>shl_coords_spatial_ref<SPAN class="punctuation token">,</SPAN>shl_fc_spatial_ref<SPAN class="punctuation token">)</SPAN>
newrow <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
newrow<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>feature<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
newrow<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>feature<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
newrow<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>projected_shl_coordinates<SPAN class="punctuation token">)</SPAN>
shl_updatecursor<SPAN class="punctuation token">.</SPAN>updateRow<SPAN class="punctuation token">(</SPAN>newrow<SPAN class="punctuation token">)</SPAN>
edit<SPAN class="punctuation token">.</SPAN>stopOperation<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
edit<SPAN class="punctuation token">.</SPAN>stopEditing<SPAN class="punctuation token">(</SPAN><SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Update: I added an 'AddMessage' statement to return the boolean value of '.isEditing' and it returns True.
Update 2: Adding the 'isEditing' before the '.startEditing' returns False.
