<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Map with legend</title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.0/js/dojo/dijit/themes/claro/claro.css"> <style> html, body { height: 98%; width: 98%; margin: 0; padding: 5px; } #rightPane{ width:20%; } #legendPane{ border: solid #97DCF2 1px; } </style> <script type="text/javascript">var djConfig = {parseOnLoad: true};</script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.0"></script> <script type="text/javascript"> dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("dijit.layout.AccordionContainer"); dojo.require("esri.map"); dojo.require("esri.dijit.Legend"); dojo.require("esri.layers.FeatureLayer"); var map; function init() { var initialExtent = new esri.geometry.Extent({"xmin":-10753431,"ymin":4624151,"xmax":-10737799,"ymax":4635884,"spatialReference":{"wkid":102100}}); map = new esri.Map("map", { extent: initialExtent}); //Add the terrain service to the map. View the ArcGIS Online site for services http://arcgisonline/home/search.html?t=content&f=typekeywords:service var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"); map.addLayer(basemap); var watershed = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Hydrography/Watershed173811/MapServer"); var waterbodies = new esri.layers.FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Hydrography/Watershed173811/MapServer/0", { mode: esri.layers.FeatureLayer.MODE_ONDEMAND, outFields: ["*"] }); //add the legend dojo.connect(map, "onLayersAddResult", function(results){ console.log("results: ", results); var layerInfos = dojo.map(results, function(r) { var li = { defaultSymbol: false, layer: r.layer }; if ( r.layer.hasOwnProperty("name") ) { // feature layer li.title = r.layer.name; } else { // dynamic layer // hide the waterbodies layer as it's added as a feature layer li.hideLayers = [0]; } return li; }); var legendDijit = new esri.dijit.Legend({ map: map, layerInfos: layerInfos },"legendDiv"); legendDijit.startup(); }); map.addLayers([waterbodies, watershed]); dojo.connect(map, 'onLoad', function(theMap) { //resize the map when the browser resizes dojo.connect(dijit.byId('map'), 'resize', map,map.resize); }); } dojo.addOnLoad(init); </script> </head> <body class="claro"> <div id="content" dojotype="dijit.layout.BorderContainer" design="headline" gutters="true" style="width: 100%; height: 100%; margin: 0;"> <div id="rightPane" dojotype="dijit.layout.ContentPane" region="right"> <div dojoType="dijit.layout.AccordionContainer"> <div dojoType="dijit.layout.ContentPane" id="legendPane" title="Legend" selected="true" > <div id="legendDiv"></div> </div> <div dojoType="dijit.layout.ContentPane" title="Pane 2" > This pane could contain tools or additional content </div> </div> </div> <div id="map" dojotype="dijit.layout.ContentPane" region="center" style="overflow:hidden;"> </div> </div> </body> </html>
Ok, i have a backwards question:
How "DO" i include the sublayers in the legend?
here is my code bringing in the layer that has the sublayers:
-----Layer: ImprovementsAll (ID: 17)
Sub Layers:
ImprovementsStanding
ImprovementsNoStatus
ImprovementsConstruction
ImprovementsMaintained
ImprovementsPaved
ImprovementsPlanning
ImprovementsRemoved
ImprovementsSold
ImprovementsUnpaved
Display Field:
Type: Group Layer
//add the improvement data
buildingsLayer = new FeatureLayer(getUrlKlondike("ImprovementsAll"), {
mode: FeatureLayer.MODE_ONDEMAND,
visible: true,
infoTemplate: template1,
outFields: ["*"]
legendLayers.push({layer: buildingsLayer, title: 'Improvements:'});
when i add the buildingsLayer to:
map.addLayers([easementsLayer, easementsSelectLayer, disposalsLayer,buildingsLayer]};
it makes it so no layers are visible and the map hangs up. Any help would be greatly appreciated. Thanks!
