How do i set the location of the Layer List when auto start is set to true. The Layer List covers up the zoom in and out buttons in the Launchpad Theme
Leo,
There is no configuration for this so you have to edit the
[install dir]server\apps\[ap number]\themes\LaunchpadTheme\panels\LaunchpadPanel\Panel.js
When you open this file find this function:
setPosition: function(position){ var style, box, row, col, size; box = this._getLayoutBox(); size = Math.floor(box.w / (position.width + position.margin)); row = Math.floor(position.index / size); col = position.index % size; position.left = (row + 1) * position.margin + col * (position.width + position.margin); position.top -= position.margin * row; position.left += 50; this.position = lang.clone(position); if(window.appInfo.isRunInMobile){ position.left = 0; position.top = box.h / 2; position.width = box.w; position.height = box.h / 2; } style = utils.getPositionStyle(position); style.position = 'absolute'; domConstruct.place(this.domNode, jimuConfig.mapId); domStyle.set(this.domNode, style); this._onResponsible(); },
and add line 11 above
This is what I'm looking at in the code, a little different than what you show.
_setPositionStyle: function(a) {
var b;
this.position.zIndex && (a.zIndex = this.position.zIndex);
this.position.left = a.left;
this.position.top =
a.top;
this.position.width = a.width;
this.position.height = a.height;
b = h.getPositionStyle(a);
e.mixin(b, a.borderRadiusStyle);
c.set(this.domNode, b)
onWindowResize: function() {
var a, b = {};
window.appInfo.isRunInMobile ? (a = "map" === this.position.relativeTo ? this.map.id : window.jimuConfig.layoutId, a = f.getMarginBox(a), b.left = 0, b.top = 0, b.width = a.w, b.height = a.h, b.zIndex = this.position.zIndex) : (b = e.clone(this.position), "minimized" === this.windowState && (b.height = this.titleHeight));
b = h.getPositionStyle(b);
b.position = "absolute";
"auto" === b.zIndex && (b.zIndex = 0);
c.set(this.domNode, b);
setPosition: function(a, b) {
var d, g, k;
b || (b = "map" === a.relativeTo ? this.map.id : window.jimuConfig.layoutId);
d = f.getMarginBox(b);
k = Math.floor(d.w / (a.width + a.margin));
g = Math.floor(a.index / k);
a.left = (g + 1) * a.margin + a.index % k * (a.width + a.margin);
a.top -= a.margin * g;
this.position = e.clone(a);
window.appInfo.isRunInMobile && (a.left = 0, a.top = 0, a.width = d.w, a.height = d.h);
d = h.getPositionStyle(a);
d.position = "absolute";
"auto" === d.zIndex && (d.zIndex =
0);
p.place(this.domNode, b);
c.set(this.domNode, d);
You are correct, the config.json will not help in this case as the widgets position is calculated in the code at runtime and is not stored in the config.json.
Thanks, I was looking under the config.json for the widget layerlist. wrong spot i suppose.
Hi Leo,
You can use any modern browser developer debugging tool to find the specific .css setting for this layerlist theme in the application.
Open the file under your project name: something may like this path:
/wwwroot/arcgis-web-appbuilder-1.2/apps/5/theme/LaunchpadTheme/stylee/default/css/jimu-theme.css
Under
/* css for jimu-panel- */ .jimu-on-screen-widget-panel, .jimu-panel {
you need to change by adding this lines:
margin-top: 270px;
Also, please take a look about this documentation to get familiar about the architecture of the Web App Builder
Development overview—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
Hope this helps
