I see multiple "dojo is not defined" errors when trying to load your app in Chrome: Uncaught ReferenceError: dojo is not defined findGrid.js:1 Uncaught ReferenceError: dojo is not defined identify.js:1 Uncaught ReferenceError: dojo is not defined index.html:27 The page also fails in IE. Can you re-visit your live link and make sure we can repro the error there?
In your app it looks like you setup the listener for the maps onLoad event but you don't have a mapReady function in your app. dojo.connect(map, "onLoad", mapReady); The basemap gallery should be created once the map has loaded so try adding the logic in the mapReady function and it should work. function mapReady(){ createBasemapGallery(); }
When I run your app with Firebug enabled I see 'Aborted' errors due to this layer. Do you have an updated version of the app?http://www.gisprod2.com/ArcGIS/rest/services/Dynamic/Zoning/MapServer?f=json&dpi=96&transparent=true&format=png8&callback=dojo.io.script.jsonp_dojoIoScript2._jsonpCallback
