Good enhancement. This functionality is not available at 10. However, it is being investigated for a future release - perhaps 10.1. For your records, I will post the NIM tracking number when I have it.
import arcpy mxd = arcpy.mapping.MapDocument(r"C:\Project\Project.mxd") df = arcpy.mapping.ListDataFrames(mxd, "Transportation")[0] for bkmk in arcpy.mapping.ListBookmarks(mxd, data_frame=df): df.extent = bkmk.extent outFile = r"C:\Project\Output\\" + bkmk.name + ".jpg" arcpy.mapping.ExportToJPEG(mxd, outFile, df) del mxd
Here is a help topic sample. If you join the beta community you'll be able to try out so much more of the arcpy.mapping functionality that was added at 10.1.ListBookmarks example 2 Similar to example 1, the following script will loop through each bookmark in the Transportation data frame, set the data frame extent, and export the data frame to a JPEG file.import arcpy mxd = arcpy.mapping.MapDocument(r"C:\Project\Project.mxd") df = arcpy.mapping.ListDataFrames(mxd, "Transportation")[0] for bkmk in arcpy.mapping.ListBookmarks(mxd, data_frame=df): df.extent = bkmk.extent outFile = r"C:\Project\Output\\" + bkmk.name + ".jpg" arcpy.mapping.ExportToJPEG(mxd, outFile, df) del mxd
import arcpy, os # The map with the bookmarks mxd = arcpy.mapping.MapDocument(r"C:\Project\BookmarksToFeatures.mxd") # The output feature class to be created - # This feature class will store the bookmarks as features outFC = r'C:\Project\BookmarkFeatures.gdb\Bookmarks' # A template feature class that contains the attribute schema # E.g. a "name" field to store the bookmark name template = r'C:\Project\BookmarkFeatures.gdb\Template' if arcpy.Exists(outFC): arcpy.Delete_management(outFC) arcpy.CreateFeatureclass_management(os.path.dirname(outFC), os.path.basename(outFC), "POLYGON", template, spatial_reference=template) cur = arcpy.da.InsertCursor(outFC, ["SHAPE@", "Name"]) array = arcpy.Array() for bkmk in arcpy.mapping.ListBookmarks(mxd): array.add(arcpy.Point(bkmk.extent.XMin, bkmk.extent.YMin)) array.add(arcpy.Point(bkmk.extent.XMin, bkmk.extent.YMax)) array.add(arcpy.Point(bkmk.extent.XMax, bkmk.extent.YMax)) array.add(arcpy.Point(bkmk.extent.XMax, bkmk.extent.YMin)) # To close the polygon, add the first point again array.add(arcpy.Point(bkmk.extent.XMin, bkmk.extent.YMin)) cur.insertRow([arcpy.Polygon(array), bkmk.name]) array.removeAll()
