I used server 10.0 to create a few map services and geodatabase services and then used web ADF (10.0) for web application development, now if I update from current version 10.0 to the 10.3.1, will the map services, geodatabase services (data service using service management tool ) be compatible? what is the overhaul for the rebuild of the project using new web ADF on 10.3.1 (I assuming there is one).
Any one has done it before? your answers are highly appreciated.
Note that, for the feature or function wise, I may not need to update to the latest version, however, when I updated the development machine to window 10, the version 10 WED ADF could not be installed at all (indicating ISS is not found ---- actually IIS running well on my computer), I saw a few threads reporting the issues, but not answers yet. Some one has figured it out? Thanks
