How can you request data using querytask/graphicslayer on a 9.3.x server in a projection that matches the basemaps' spatial reference if this is only defined as a wkt? Ie if you can get data from a 9.3.1 server that overlays correctly on your map, there must be a valid wkid for that map that you can use instead of the wkt.Either that, or you are mixing spatial references which could lead to some major accuracy issues.On a side note my experience is that projection on the fly is not really a big overhead at all. Most of the performance issues is usually from pulling shapes out of the database and rendering it to the image. If you have issues with performance this is really stuff you should be looking at instead (msd and/or caching will also help way more than what you loose on reprojection)
