Claire, You may have noticed by now that the limited set of functionality previously available on the Spatial Analyst toolbar is removed in ArcGIS 10. The full functionality of Spatial Analyst has always been in ArcToolbox > Spatial Analyst Tools. The tool you are looking for is called Cost Path located in the Distance toolset.Cost Path can be used to derive the path of least resistance down a digital elevation model (DEM). In this case, use the DEM for the Input cost distance raster and the output from the Flow Direction tool for the Input cost backlink raster.For those having problems using the interactive Steepest Path tool, I would suggest filling your DEM. I think you may have sinks and that could be why the path created is so short. Alternatively, use the Cost Path tool to do your analysis.Best Regards,Eric
Eric,When using the Cost Path tool to derive the path of least resistance, its my understanding that it requires two input points, A and B. It then traces the shortest path from point A to point B.However in Arc 9.x the shortest path tool only required one input point, A, and it then traced the shortest path from point A to the edge of the DEM, which effectively becomes point B.Therefore the shortest path tool and cost path tool are slightly different. I have a similar problem to Claire as regards tracing a surface water run-off path into the river/sea and it would be great if you could advise of a similar tool in Arc 10.Kind regards,Tony
What I don't quite understand is what my input equivalent to your "Raindrops" input should be. The Cost Path tool requires it to be a raster, but it appears to me that your input -- several raindrops -- is a point layer. Can you clear this up for me? Clearly my knowledge of raster processing is sorely lacking.
Hi Tony,The Shortest Path tool and the Cost Path GP tool are the same tool with different names. I don't have 9.x installed to take the screenshots necessary to highlight this so I'll just point you to some documentation.Under Analysis Concepts > Distance Analysis > Least Cost Path and Least Cost Corridor you'll find generic information regarding what cost path/corridor analysis is and how to perform it in ArcGIS. On this page you will find instructions (Links) to Learn how to calculate least cost path using the Spatial Analyst toolbar and to Learn how to calculate least cost path using the Cost Path tool In the Usage Tips section (for the GP tool documentation) it states the following:"Cost Path can also be used to derive the path of least resistance down a digital elevation model (DEM). In this case, the DEM will be the input cost distance raster and the flow direction raster will be the input cost backlink raster. Valid flow direction raster values are 1, 2, 4, 8, 16, 32, 64, and 128; valid values in the backlink raster are 1, 2, 3, 4, 5, 6, 7, and 8. Both of these rasters are acceptable."Attached are screenshots of a simple model I made and the results overlaid on a hillshade to give you some perspective.
