Thank you for providing help on this. My actual problem was the arrow with the drop down list on the measurement widget was not showing up. I found that the display of the arrow element is set to "none" by default. I had to overwrite that attribute by placing this block in my CSS file
.dijitArrowButtonChar {
display:inline !important;
This is easy. There's a buildIn function to hide or show the three Types of measurement called hideTool('toolname').
Just insert the Toolname you don't want to see.
To change the default Unit for Area-Measurement use defaultAreaUnit and for changing the default length Unit use defaultLengthUnit.
For further Informations have a look here : Measurement | API Reference | ArcGIS API for JavaScript
Regards
I also have the same requirement. Did one one figure out how the css element style can be changed for the elements inside the measurement widget?
<span class="dijit dijitReset dijitInline esriToggleButton" style="visibility: visible;" widgetid="unit"> <span class="dijitReset dijitInline dijitButtonNode" dojoattachpoint="_buttonNode" dojoattachevent="ondijitclick:_onButtonClick"> <span id="unit" class="dijitReset dijitStretch dijitButtonContents dijitDownArrowButton" aria-labelledby="unit_label" aria-haspopup="true" role="button" dojoattachpoint="focusNode,titleNode,_arrowWrapperNode" style="-moz-user-select: none;" tabindex="0"> <span class="dijitReset dijitInline dijitIcon" dojoattachpoint="iconNode"></span> <span id="unit_label" class="dijitReset dijitInline dijitButtonText" dojoattachpoint="containerNode,_popupStateNode" style="font-size:16px !important;" popupactive="true">Miles</span> <span class="dijitReset dijitInline dijitArrowButtonInner"></span> <span class="dijitReset dijitInline dijitArrowButtonChar">�?�</span> </span> </span> <input class="dijitOffScreen" type="button" dojoattachpoint="valueNode" tabindex="-1" value="unit"> </span>
var location = dojo.query('[widgetid=\"location\"]')[0]; location.parentNode.removeChild(location);
var measurement = new esri.dijit.Measurement({ map: map }, dojo.byId('measurement')); measurement.startup(); var area = dojo.query('[widgetid=\"area\"]')[0]; area.parentNode.removeChild(area);
I am also curious how to modify this widget. I want to change the text size of the drop down menu (ie: where it says Miles, kilometers, etc) as well as shrink down some other elements of it. I cant figure out the CSS to change in order to modify the measurement widget beyond changing what the icons are.
