I am still having problems with this tool, always getting an empty output. I have tried the Check Geometry and Repair Geometry tools as per a different post, and I've tried saving the output table in a file geodatabase, as a table, and as a DBF, but none of these solutions has worked. I have even tried projecting the data from NAD 27 to Web Mercator (using geographic transformation NAD27 to WGS84_3) thinking that maybe the tool was having trouble calculating the areas in degrees rather than meters, but still nothing.
I'm working with data for Canada, namely provinces (the zones) and eco regions (the input class). I've tried just about every combination of parameters I can think of, but I get an empty output table every time. Both features are polygon shapefiles.
I'm really stumped. Any help would be appreciated.
Hi Talsan,
Are your shapefiles z or m-enabled? If one of them is and the other is not, perhaps that could be the problem.
-L
