Jennifer, Thank you for your reply. I was trying to edit each selected Graphic.Geometry object directly and change it's vertices. But when I tried to save the changes were lost. What did work was making a clone of the geometry, editing the vertices, and then assigning the clone back to the Graphic.Geometry object. Now I can move and rotate groups of polygons together. Here's the code I used to move polygons. foreach (var graphic in flayer.SelectedGraphics) { _edit_Geometry.StartEdit(graphic); ESRI.ArcGIS.Client.Geometry.Geometry geom = ESRI.ArcGIS.Client.Geometry.Geometry.Clone(graphic.Geometry); ESRI.ArcGIS.Client.Geometry.Polygon polygon = geom as ESRI.ArcGIS.Client.Geometry.Polygon; if (polygon != null) { foreach (var ring in polygon.Rings) { IEnumerator<MapPoint> points = ring.GetEnumerator(); while (points.MoveNext()) { points.Current.X = points.Current.X + changeinX; points.Current.Y = points.Current.Y + changeinY; } } } graphic.Geometry = geom; _edit_Geometry.StopEdit(); }
If you are using Editor.EditVertices, I don't see a reason why edits are not saved since geometries are first simplified before it overwrites your geometry. If you are using EditGeometry, you may need to simplify the geometry first: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#Simplify. Kindly check Fiddler when saving this edit, SpatialReference on Geometry might be missing. If so, we have logged this bug in EditGeometry.
