import arcpy, os, zipfile infile = arcpy.GetParameterAsText(0) outpath, outfileext = os.path.splitext(infile) filename = outpath.split('\\')[-1] try: # unzip file fireZip = zipfile.ZipFile(infile, 'r') fireZip.extractall(outpath) fireZip.close() shpPath = outpath + "\\" + filename + ".shp" arcpy.AddMessage("Finished unzipping file.") # Local variables: WildFire_Table_Target = "Database Connections\\SQL_DB(TEST Server).sde\\ArcSDE.dbo.WILDFIREPERIM" # Create FieldMappings object and load the target dataset fieldmappings = arcpy.FieldMappings() fieldmappings.addTable(WildFire_Table_Target) inputfields = [field.name for field in arcpy.ListFields(shpPath) if not field.required] for inputfield in inputfields: # Iterate through each FieldMap in the FieldMappings # for i in range(fieldmappings.fieldCount): fieldmap = fieldmappings.getFieldMap(i) #arcpy.AddMessage(fieldmap.getInputFieldName(0)) # If the field name from the target dataset matches to a validated input field name # if fieldmap.getInputFieldName(0) == inputfield.replace("", ""): # Add the input field to the FieldMap and replace the old FieldMap with the new # fieldmap.addInputField(shpPath, inputfield) fieldmappings.replaceFieldMap(i, fieldmap) break # Process: Append arcpy.Append_management(shpPath, WildFire_Table_Target, "NO_TEST", fieldmappings) except Exception as e: print e.message arcpy.AddError(e.message)
Create FieldMappings object and load the target dataset # fieldmappings = arcpy.FieldMappings() fieldmappings.addTable(WildFire_Table_Target) inputfields = [field.name for field in arcpy.ListFields(shpPath) if not field.required] for inputfield in inputfields: # Iterate through each FieldMap in the FieldMappings # for i in range(fieldmappings.fieldCount): fieldmap = fieldmappings.getFieldMap(i) #arcpy.AddMessage(fieldmap.getInputFieldName(0)) # If the field name from the target dataset matches to a validated input field name # if fieldmap.getInputFieldName(0) == inputfield.replace("", ""): # Add the input field to the FieldMap and replace the old FieldMap with the new # fieldmap.addInputField(shpPath, inputfield) fieldmappings.replaceFieldMap(i, fieldmap) break
Geoprocessor geoprocessorTask = new Geoprocessor("http://mygisserver/arcgis/rest/services/GPTools/WildfireUpload/GPServer/ZipImportTest"); geoprocessorTask.ExecuteCompleted += GeoprocessorTask_ExecuteCompleted; geoprocessorTask.Failed += GeoprocessorTask_Failed; List<GPParameter> parameters = new List<GPParameter>(); parameters.Add(new GPItemID("Input_File", "iec5a4db4-33c9-40b9-ab82-cd27ecef279f")); //http://gis/arcgis/rest/services/GPTools/WildfireUpload/GPServer/uploads/iec5a4db4-33c9-40b9-ab82-cd27ecef279f old file link geoprocessorTask.ExecuteAsync(parameters);
{"itemID":"i80dfa12f-52ed-4841-94ff-37f9c3f5dd6f"}
Sorry I got ahead of you there. Because I needed to perform the field mapping on the fly i switched from using a model to using a python script. The input parameter type is going to be "File" in any case. In the script below, "infile = arcpy.GetParameterAsText(0)" is going to get the input file as a File type parameter. Then you can use the file as you please. You will see when you run this in desktop you have a file browser that you can use to browse to a file of your choice. Once you get that to run succesfully you can publish as a service. With the service you will need to get the itemID of the uploaded file and use that as an input parameter like itemID:"i83fa38d5-69e8-40c0-bd9c-30beb643e522". import arcpy, os, zipfile infile = arcpy.GetParameterAsText(0) outpath, outfileext = os.path.splitext(infile) filename = outpath.split('\\')[-1] try: # unzip file fireZip = zipfile.ZipFile(infile, 'r') fireZip.extractall(outpath) fireZip.close() shpPath = outpath + "\\" + filename + ".shp" arcpy.AddMessage("Finished unzipping file.") # Local variables: WildFire_Table_Target = "Database Connections\\SQL_DB(TEST Server).sde\\ArcSDE.dbo.WILDFIREPERIM" # Create FieldMappings object and load the target dataset fieldmappings = arcpy.FieldMappings() fieldmappings.addTable(WildFire_Table_Target) inputfields = [field.name for field in arcpy.ListFields(shpPath) if not field.required] for inputfield in inputfields: # Iterate through each FieldMap in the FieldMappings # for i in range(fieldmappings.fieldCount): fieldmap = fieldmappings.getFieldMap(i) #arcpy.AddMessage(fieldmap.getInputFieldName(0)) # If the field name from the target dataset matches to a validated input field name # if fieldmap.getInputFieldName(0) == inputfield.replace("", ""): # Add the input field to the FieldMap and replace the old FieldMap with the new # fieldmap.addInputField(shpPath, inputfield) fieldmappings.replaceFieldMap(i, fieldmap) break # Process: Append arcpy.Append_management(shpPath, WildFire_Table_Target, "NO_TEST", fieldmappings) except Exception as e: print e.message arcpy.AddError(e.message)
Hi I tested your code, but it return this error: IndentationError: unindent does not match any outer indentation level How should I set script input and output parameters?
Just be sure to check your python code to make sure none of the lines are wrapping on you. Does it say what line the indentation error is on?There is one input parameter scripted in this sample. infile = arcpy.GetParameterAsText(0). If you need more you can just take a similar appraoch.
The error is for Line 41.
I am not exactly sure what your line 41 would be. i would assume you changed the code as least a little bit so my line 41 is not the same as yours. If you can post your code and state the text of the line that is giving you issues I can see if I can identify the issue. When posting your code make sure it posts with the correct indents and line breaks or it could make it look like you have more problems that aren;t necesarily in your code.
Honestly it is probably just an issue with the indentation due to copying and pasting. I would just go though and make sure everything is indented properly. Using a program like notepad++ will make it easier to spot issues. When I copied my code below into NP++ you can see that line is indented too much as well as 2 other below it. Just delete the white space before that following 3 lines and tab them each over 1 time. arcpy.Append_management(shpPath, WildFire_Table_Target, "NO_TEST", fieldmappings) print e.message arcpy.AddError(e.message)
You are going to have to post your code to this thread using code blocks. Without that I will not be able to properly view your code with the correct indenting.
I attached pyton script. please help me.
The last few statements you have a incorrect. You need to use with the appropriate indentation. # Process: Append arcpy.Append_management(shpPath, WildFire_Table_Target, "NO_TEST", fieldmappings) except Exception as e: print e.message arcpy.AddError(e.message)
HiI tested your code, but it return this error:IndentationError: unindent does not match any outer indentation level (import_zip_91.py, line 40)What is appropriate indentation?Please help me more. Is it possible to send me your model or your code?Regards
It is pretty simple at this point. You just need to make sure your indentation is correct on those lines that I posted last. Delete the white space before each line so they are not indented and then tab each line over 1 time. The only exception is "except Exception as e:": should not be indented at all.
HiI did it, But it return "Invalid syntax error"!!!
I am trying to create a service that allows a user to upload a zip file that contains a shape file, unzip it, and finally append to an existing GDB Feature Class. The fields in the shape file do not match the FC so I need to performa field mapping. However, since the input is a zip file I do not have the capabilty to set up the field mapping in the model. So when I run this it adds the elements of the shape file but all the attributes are blank because the missing mapping. Is there any way around this? [ATTACH=CONFIG]19948[/ATTACH]
Bleroux�??:You are a big mendacious...You tell tattle...You are not going to help people in this blog, just Pull someone's leg...Otherwise help them. I was Following-up this forum 3 month ago and came to this bad conclusion of your terrible answers!
