Gotcha! thanks!
No, once the Geodatabase is created with SDE Owned schema....you cannot change it to DBO Owned Schema. You will need to recreate the Geodatabase for that.
Great!
This seems to work for me, however what if my database is already created? Is there any way to remove the 'Sde Owned Schema' after it was checked while creating the geodatabase?
I had this issue recently. I was trying to enable an enterprise geodatabase on an existing SQL Server 2012 db on Amazon RDS. The enable process seemed to go through successfully. But when I tried to connect using this "master" sde connection, it gave me the same error.
The issue ended up being a user name/schema name mismatch. When I created the database in SQL Server Management Studio, the "master" user name was mapped to the "dbo" schema in the new database. Once these were set to match the error went away.
