I am trying to add domains to the editor widget's layer infos property. I can't seem to be able to make it work.
Here is a sample of what I am trying to do : https://codepen.io/mtrsklnkvMM/pen/rNNrYxd
The domain property doesn't seem to be doing anything.
I found the "problem". When coding your domains, you need to specify the type ("coded-value"), otherwise the _isDomainCompatible() function in the VM won't work. I guess I somehow believed it would "autocast".
domain:{ codedValues: [{code:'Yes',name:'Yes'},{code:'No',name:'No'}], type:"coded-value"}
I modified the pen above.
Any ideas? We'd really like to add domains (in code) when using the editor widget.
