So is there a warning that the data will be copied to the server or no?
If you have ArcGIS Desktop on the same machine as ArcGIS Server (AGS), then you will also need the 32 bit Oracle Client since ArcGIS Desktop is still 32 bit software. There is ESRI documentation on this scenario in the setup for AGS. I believe it will not copy the SDE data to the server once the 32 bit client is installed as I ran across this same scenario myself.
