Thanks for the help. The Aggregate Polygon tool seems to work for my use-case-scenario, when I split up my building shapefile into the number of classes I have (i would probably have to clip the results later on, since there might be some slight overlaps of the polygons in the end).However, the Delineate Built-up Area Tool seems to be the better fit. Is there a way to include an attribute class field in the calculation? The Identifier-Field has a different task than what I am looking for. Im also experiencing some trouble with the Minimum Detail Size Field. Ive tried several different sizes there, but I always receive the "error 000200 : Error in building map context. Reference scale is not defined." which is wrong, because all my shapefiles are referenced as well as the data frame. Any idea? Great video-tutorial by the way 🙂
Richard, thanks for your idea. The dissolve tool works in the way you described it, however this is not the result I was aiming for. I actually want the buildings to spread out and create a new polygon topology, so that the spare room between the buildings are also covered by the polygon. Those polygons should be created according to the 8 classes, but I would prefer several polygons for each class (because the urban area im trying to cover is actually pretty large) and not just one multipart-feature for each class. Do u have a solution for this case in mind? Im sorry, that my first post was a bit sloppy in regards to my purpose. Thanks, greetings.
Hey guys,i have the following problem: I have a set of buildings (either as a polygon, or if needed as centroid points) which I want to "sum up" in larger polygons. My buildings are classified in 8 different classes (as attribute), which should be used for calculating the larger polygons. Basically I would like to have a set of polygons, divided in 8 classes, which cover the whole urban area. So far, I havent found a solution which fits my case. Does anyone of you have an idea, how to do this?Thanks in advance, greetings.
