Thanks for your response. Yes, your suggestion does work.html<body class="override nihilo">css.override .templatePicker { margin-top: 15px; border:none; }I believe the reason it works is not because class override is assigned before class nihilo, in my case, but because the css selector ".override .templatePicker" has higher specificity than simply ".templatePicker". The ".templatePicker" class selector is not in the dojo nihilo or tundra, etc. themes but rather in a separate css pulled from ESRI CDN.http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/esri/dijit/editing/css/TemplatePicker.cssTherefore, this works too -> <body class="nihilo override">Thx.
If you add a class to your <BODY class="override tundra"> and then add a css entry as .override .templatePicker { margin-top: 10px; border:none }It will pick yours first, since "override" comes before "tundra" in the list
I notice the ESRI dijits I'm using have their own styles in css that are pulled from the CDN (I'm using the CDN-hosted api, v2.5). At times, I'd like to override some of those styles with my own local styles. Since the esri css are loaded last, they always trump any local styles I have set. The only workaround I found is to use !important. For example, for the editor template picker: .templatePicker { margin-top: 10px; border:none !important; /*override esri legend.css*/ }to override this css...http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/esri/dijit/editing/css/TemplatePicker.cssI don't think this is the best approach but don't know of another way.
