I'd say the easiest way is to run a Frequency (or Summary Statistics) on the capture date (depending on how it is formatted), export the duplicates and set up a topology enforcing the rule 'Must Not Overlap'. Of course, you may have to consider tolerances on neighboring polys?...If that's the case, you may try something else; if overlapping polys are generally the same shape/area, maybe Feature to Point (again, for duplicates only), then analyze how close together points are. Those in close proximity are suspect and warrant closer inspection.
