I'm doing some coding in Python with ArcPy with fishnets, and I'm trying to understand more about the tool.
Specifically, the documentation refers to:
origin_coord | The starting pivot point of the fishnet. | Point |
y_axis_coord | The Y-axis coordinate is used to orient the fishnet. The fishnet is rotated by the same angle as defined by the line connecting the origin and the y-axis coordinate. | Point |
I'm having trouble understanding, visually, what the origin coordinate is and what the y_axis_coord is. How does this work?
Secondly, I'd like to be able to specify the extent of the fishnet using latitude and longitude, which is an option (I think):
template (Optional) | Specify the extent of the fishnet. The extent can be entered by specifying the coordinates or using a template dataset. - Left—XMin value
- Right—XMax value
- Bottom—YMin value
- Top—YMax value
| Extent |
How does this option interact with the required parameters of origin_coord and y_axis_coord?
