How do you get the Network Analyst to use the sequence you specify in a Vehicle Routing Problem layer? I can get the routes to show up in the Route Analysis layer, but I can't get them to start and finish at a single depot like I can in the VRP.
I need to use a specified route sequence from a regularly relocated depot and need to know which tool to use short of hard-coding the depot's location into the Stops sublayer within the Route Analysis layer.
I could not get the Routes shape from the Network to output
1. I have a sheet that documents the order that stations are currently visited by the collectors. How do I assign a specific sequence to a route? The sequence is stored as a field in the point file.
2. How can I use modelbuilder to automatically output statistics (like overall travel times per route) to a table?
