Anyone please let me know if you have been successful in getting this applet to work. I am utilizing a Leica Zeno device running ArcPad (Zeno Field) and Zeno Office on ArcMap on a desktop.
I've tried this many times, also with a network RTK unit running ArcPad. When the script populates the various coordinate quality fields and it does not appear to be in any sort of measurable unit.
The applet will provide DOP’s (HDOP, GDOP, etc.) but these are not useful. We need a unit of measure of statistical error approximation.
We need to be able to provide a standard deviation or coordinate quality in meters or feet.
Example: 0.02ft horizontal, 0.04ft vertical, 0.06ft 3DCDQ.
The XYZ applet populates the QUALITY field, but it doesn’t seem to have any unit to it, no matter if it is set up as a text or numerical field. It’s either 0,1 or 4. I don’t know what these numbers relate to. I cannot figure any type of conversion from this to coordinate quality in 1D, 2D, or 3D, in any particular unit of measure. See Point Feature Attribute Table and corresponding Point Details shown below. If you are aware of anyone successfully utilizing the XYZ applet to get a coordinate quality, please let me know how they are doing it.
Attribute Table:
GNSS Point Details - As you can see here at the bottom of the point details, the XYZ Applet should be showing Qualities of 2D=0.015ft, 1D=0.086 or a 3D or approximately 0.11ft.
Well I read a little further on the XYZ applet...... Not sure if this will work for me since it says for Garmin GPS only.
"EPE" Estimated position error of the GPS (for Garmin® GPS receivers only). Double
"HDOP" Horizontal dilution of precision of the GPS. Double
"HPE" Horizontal position error of the GPS (for Garmin® GPS receivers only). Double
"PDOP" Position dilution of precision of the GPS. Double
"SATS_USED" Number of satellites used for the current position. Long
"QUALITY" GPS fix quality Long - 0 = Invalid- 1 = GPS fix- 2 = DGPS fix
"DIFF_AGE" Age of the current differential signal (in seconds) Long
"DIFF_ID" ID of the DGPS station used. Long
Hello all,
As of ArcPad 10.2, you are also able to use QuickFields to auto populate GPS info into your data.
Please see here for more information about QuickFields: ArcPad Help
The GPS options available in Quick Fields is as follows:
- Hannah
What version of ArcPad are you using? I cannot get the XYZ Applet to work on 10.2, I tried on multiple devices.
I'm trying to use quick fields also, but that is coming up short because help provides limited information on the syntax. I also don't like the idea of something that can be turned off.
