How do I simply align the edges of two polygons in ArcGIS pro? I digitized them and the lines don't match up perfectly, but there must be a better way than to go and edit all individual vertices by hand.
Hi Louise, where was the answer to this question posted? I am currently experiencing the same issue
Hi Emily, did you ever find an answer to this? I am currently experiencing the same problem
Hi Emily, did you ever find an answer to this question? I recently encountered the same issue.
Does the screen for the tool you are using look like this:
In this scenario I have 2 adjacent polygons selected and I then need to draw an alignment path that follows the border of 1 of the 2 polygons. This is just an exaggerated example as I'm sure your polygons are not off by 2,000 feet. After I draw a path and double-click to end the lines path I will see a polygon that shows the alignment area and the Align button should then be enabled.
There was no list of actions on the right side of my screen. I found a Gear drop down menu next to my question but the only options are "Following", "Share", and "Bookmark". I would like to learn. What am I missing? Thanks for your help.
New to GIS with Pro. I have looked up how to use the align features tool and I can't seem to get the "Align" Button to activate.
Have you ever tried this operation in ArcMap? Or are you new to GIS with Pro?
This document in our GeoNet Resource Hub should cover the steps you need Moving Content. If you need me to do it on your behalf then just let me know. Happy to help.
Thanks, how do I move it?
Hi Emily, thanks for the question. Looks like this question might benefit from being moved to the ArcGIS Pro space on GeoNet in order to find the right community experts to help with your question. If you are happy to move it or need help to do that then let me know.
