<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:esri="http://www.esri.com/2008/ags" pageTitle="Salt Lake County Surveyor" xmlns:flexScript="flexScript.*" preloaderChromeColor="#F9F6F6" backgroundColor="#F7F4F4"> <fx:Script> <![CDATA[ import com.esri.ags.geometry.MapPoint; import com.esri.ags.Graphic; import com.esri.ags.events.QueryEvent; import com.esri.ags.events.IdentifyEvent; import mx.controls.Alert; import mx.rpc.AsyncResponder; import mx.rpc.Fault; import com.esri.ags.FeatureSet; import com.esri.ags.Graphic; import com.esri.ags.events.MapMouseEvent; import com.esri.ags.geometry.Extent; import com.esri.ags.geometry.Geometry; import com.esri.ags.geometry.MapPoint; import com.esri.ags.geometry.Polygon; import com.esri.ags.geometry.Polyline; import com.esri.ags.symbols.InfoSymbol; import com.esri.ags.tasks.supportClasses.IdentifyParameters; import com.esri.ags.tasks.supportClasses.IdentifyResult; private function onMapClick(event:MouseEvent):void { // init indentify parameters var identifyParams:IdentifyParameters = new IdentifyParameters(); identifyParams.geometry = map.toMapFromStage(event.stageX, event.stageY); identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_VISIBLE; identifyParams.returnGeometry = true; identifyParams.tolerance = 3; identifyParams.width = map.width; identifyParams.height = map.height; identifyParams.mapExtent = map.extent; identifyParams.spatialReference = map.spatialReference; identifyTask.execute( identifyParams, new AsyncResponder( onIdentifyComplete, onIdentifyFault )); } private function onIdentifyComplete( event:Object, token:Object=null):void { graphicsLayer.clear(); if ( event.length > 0 ) { // take first result var graphic:Graphic = event[0].feature; var name:String = graphic.attributes.MUKEY; var siteindexwa:String = graphic.attributes.siteindexwa; var siteindexmvwa:String = graphic.attributes.siteindexmvwa; var content:String = "Name : " + name + "\n"; content += "Site Index WA : " + siteindexwa + "\n"; content += "Site Index mvwa:" + siteindexmvwa var mapPoint:MapPoint = graphic.geometry as MapPoint; var myInfoPopup:MyInfoPopup = new MyInfoPopup(); myInfoPopup.content = content; map.infoWindow.label = "Soils Information"; map.infoWindow.content = myInfoPopup; map.infoWindow.show( mapPoint ); // -- OR -- // loop thru entire result set... // for each( var result:IdentifyResult in event ) // { // var graphic:Graphic = result.feature; // } } } private function onIdentifyFault( event:Fault, token:Object=null ):void { Alert.show( event.toString() ); } ]]> </fx:Script> <fx:Declarations> <esri:IdentifyTask id="identifyTask" url="http://tfsgis-iisd01:6080/arcgis/rest/services/Fernando/SoilsRaster/MapServer" /> <esri:IdentifyParameters id="identifyParams" /> <esri:SimpleMarkerSymbol id="symbol" color="0xCCCCEE" size="20" alpha="1" style="circle"> <esri:SimpleLineSymbol color="0x0000FF" width="4" alpha="1" style="solid" /> </esri:SimpleMarkerSymbol> </fx:Declarations> <esri:Map id="map" click="onMapClick(event)"> <esri:extent> <esri:Extent xmax="-9438000 " xmin="-12363000" ymax="4500000" ymin="2930000"/> </esri:extent> <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/Canvas/World_Light_Gray_Base/MapServer"/> <esri:GraphicsLayer id="graphicsLayer"/> <esri:ArcGISDynamicMapServiceLayer url="http://tfsgis-iisd01:6080/arcgis/rest/services/Fernando/SoilsRaster/MapServer"/> </esri:Map> </s:Application>
<?xml version="1.0" encoding="utf-8"?> <mx:Canvas xmlns:mx="http://www.adobe.com/2006/mxml"> <mx:Script> <![CDATA[ [Bindable] public var content:String; ]]> </mx:Script> <mx:VBox width="100%" height="100%" backgroundColor="0xEEEEEE"> <mx:Text text="{content}"/> </mx:VBox> </mx:Canvas>
