Hi all
My question is about publish MapServices. If I publish a MapService from ArcGIS Pro with "Copy all Data" and LayerType "Map Image". After this publish process are the data in the datastore? If yes, is there a way to directly connect to the data? ArcGIS Pro, ArcCatalog others? If no, where are the data stored?
Cheers
If you publish a map service from ArcMap and copy data to the Server, the data will live in the arcgisinput folder, ex C:\arcgisserver\directories\arcgissystem\arcgisinput\<service>\extracted\v101. I'm not sure if that's the same with Pro, but that's a place you can look. Pretty sure it'll be the same location.
GIS Mountains,
If the ArcGIS Datastore is not setup, then the location Jonathan refers to is where you would look.
However, if the ArcGIS Datastore is setup as a "Managed Database" in a federated/hosted arcgis server (that is attached to your Portal), than the data is automatically copied to the Datastore. If this is the case, you can directly access the content in your Portal and pull it down into ArcMap/ArcGIS Pro by accessing my content and finding your feature services.
If you want to edit the data, you need to enable that when you publish your content. Also, if you are publishing entire map services, you can always edit the data locally and overwrite your services when you have a change.
~Alex
Hi Alexander and Jonathan
Thank you for the response.
I checked the directory on the ArcGIS Server. There is a fgdb in the following directory:
\arcgisserver\directories\arcgissystem\arcgisinput\<servicde>.MapServer\extracted\p12\<servicde>_alias.gdb
When the servers creates the map-picture is it using the data in this fgdb or are there the same data in the datastore?
How can I check if there is the same data in the datastore? Connect with pgadmin tp the postgres? Connectionstring?
The map service is utilizing the data in your FGDB here: \arcgisserver\directories\arcgissystem\arcgisinput\<servicde>.MapServer\extracted\p12\<servicde>_alias.gdb
Do you have a datastore attached to Portal/ArcGIS Server? If your data was copied to the arcgisserver directory, I would think you do not have a "managed database" with the ArcGIS Datastore.
As for connecting, it was not intended for your to connect with ArcCatalog to the ArcGIS Datastore.
This is a good thread on the topic:
https://community.esri.com/thread/160435
Hello Alexander
Yes, the datastore is attached to the Portal/ArcGIS Server. It is configured in the ArcGIS Server Manager. The ArcGIS Server is federated with the Portal for ArcGIS and is configured as hosting server. The ArcGIS Enterprise version is 10.5. Portal for ArcGIS, ArcGIS Server and the Datastore (relational) are installed on 3 different server as recommended. It works to "Publish hosted feature layers", from ArcGIS Pro and as upload with Portal for ArcGIS.
For me is still not clear: Is something wrong with our configuration and the data for a mapservice should be in the datastore? Or is the situation that the data are stored in a fgdb on the filesystem on ArcGIS Server the way how it is?
Thank you, yes I know this thread. Is it possible to connect to the postgres with pgadmin? connection string?
I am glad to hear you have a Base deployment of Enterprise 10.5. Even better to hear that you followed best practices in your implementation, separating the components for workload separation! I just published to my 10.5 Enterprise instance (with fully federated/hosted ArcGIS Server).
If you are publishing as a "web map":
If you "Copy all Data" using ArcGIS Pro, and have a hosting server, it looks like the data is stored in a folder called:
\arcgisserver\directories\arcgissystem\arcgisinput\<map service name>.MapServer\extracted\p12 - has data for web map (since not feature services)
If you publish a multi layer map as a "web layer" (which will create feature services):
There should be a folder in your ArcGIS Server directory:
\arcgisserver\directories\arcgissystem\arcgisinput\Hosted
The feature service should appear in that Hosted folder and if you drill down to the v101 folder, there should be no FGDBs.
\arcgisserver\directories\arcgissystem\arcgisinput\Hosted\<feature service name>.FeatureServer\extracted\v101 - should not contain data. If this is not the case, I would be curious to see if you published a single layer as "web layer" and investigate where this data was uploaded to.
I believe it is worth mentioning, you can have registered databases/folders in ArcGIS Server still...which would keep the data in the file system or enterprise SDE.
As far as connection directly to the datastore, I have heard there are ways you can go about it, but I do not think Esri supports that workflow directly. Just be careful if you do connect and manipulate data, as I do not believe tech support can help you with recovering or fixing that datastore.
Just to add to this, if you're publishing a map service from data that is not registered, it's going to copy the data into the arcgisinput folder. If you're publishing a map service with feature access using data that's not registered, it'll copy data into the ArcGIS Data Store and create a traditional map service that spins up an ArcSOC.exe process. If you're publishing a feature service directly to Portal, the data still goes into the ArcGIS Data Store, but you're publishing a "hosted feature service" that won't spin up an ArcSOC.exe process.
Since you're publishing a map service, the data won't be copied into the ArcGIS Data Store. Once you publish a service that requires a relational database to store the data, (any feature service), it'll copy the data into the ArcGIS Data Store.
