My application will create new feature points, but will not update existing points. Is there different syntax besides the applyEdits to perform an update? I have debugged and the attributes are there when I start. They just don't take, which is why I thought my syntax may be wrong.
Here is a block of code that I am trying to use for one of the updates:
// get sign attributes from form and submit
var updateSigns = function () {
// alert(domClass.contains("attributesSignModal", "in"));
var attributes = {
// TODO: not sure if this is needed
//requestreceived: null
var currentDate = new Date(); // current date is defined but never used.
var graphic;
graphic = new Graphic(app.currentGeometry);
query("#attributesSignModal input, #attributesSignModal select, #attributesSignModal textarea").forEach(function (formInput) {
attributes[formInput.name] = formInput.value;
// Form validation - ensures that the values for the data are here if left blank
if ((attributes.installed === undefined) || (attributes.installed === "")) {
attributes.installed = null;
if ((attributes.signId === undefined) || (attributes.signId === "")) {
attributes.signId = null;
if ((attributes.supportId === undefined) || (attributes.supportId === "")) {
attributes.supportId = null;
graphic.setAttributes(attributes);
stopCaptureRequest();
console.log(attributes);
app.signLayer.applyEdits(null, [graphic], null).then(function (response) {
console.log(response);
app.signLayer.refresh();
};and here is an addSign that does work:
var addSigns = function () {
var attributes = {
var graphic;
query("#attributesSignModal input, #attributesSignModal select, #attributesSignModal textarea").forEach(function(formInput) {
if ((attributes.installed === undefined)|| (attributes.installed === "")) {
app.signLayer.applyEdits([graphic], null, null).then(function (response) {
};and finally, here is my latest github commit:
csergent45/streetSigns at 787b3ed59a446ca1cfcb8229d696b3445c4dda59 · GitHub
