Hi All,I'm having to use ArcGIS 10 to export a map to PDF, and followed the 'export map to pdf using python geoprocessing toolbox' approach detailed at the following URL. I've had some success, it actually prints the PDF with some layers...but...the ESRI basemap layers are not included in the map when I access the geoprocessing toolbox through the REST service "Submit Job/Execute Task". If I run the 'ExportToPDF' tool on my local machine...it works perfectly...just not through the web service...I've viewed the messages and it's running without error...but the resulting PDF only has my 'operational layers', but NOT the ESRI basemap.I've run out of ideas on this one...anybody have an idea? I've also attached my result...thanks,Danhttp://www.arcgis.com/home/item.html?id=8f16fdeef39c46b3952002b2d85ea5de
Permissions could be the issue...any idea which directory is used to download tiles before creating the PDF?I just tested an external/public map service and I'm having the same issue...so seems like you might be onto something. Just have to figure out which directories to give permissions...will poke around the ArcGIS Server Manager and see if any directories are listed there.will let you know 🙂
I've checked the logs, no help there. But I see the list of "Server Directories" in ArcGIS Server Manager..and am hoping that it's one of those. I have a request in to get permissions for those directories just to test it out.
