Buy normal operation like query / identify fails. i tried logging the rest api request and tried running it on browser
but it gives error line Geometry not found.....
Any ideas...
Does your client's map service support Identify and find operations?
Hi Riyas,
Well I am using ArcGIS Server 10.0. Under capabilities Tab I see the operations allowed are
Map
Query
Data
All the above are checked, I also check the FIND option in ArcMap for the same map (mxd file) and I able to FIND.
Is this what you meany by identify and find operations?
Hi Jaganvas,
Can you use your client's map service in this sample? ArcGIS API for JavaScript Sandbox If it works here, then it is a code issue you may want to investigate your code.
If it does't work here then it is the map service double check to make sure it supports and query and identify operations.
