The first question is, is the advice you have provided so far the correct way to implement the end product?
Well the code I inserted does not seem to run. I placed it at the end just before } dojo.addOnLoad(Init);
var app = {}; app.printUrl = "http://gisprod2/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task";
<div id="print_button"></div> <div id="info"> <a href="http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/printtemplate.htm">Print templates</a> are generated from the Export Web Map Task's <a href="http://servicesbeta2.esri.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task">Layout_Template parameter</a>. This info is retrieved from the service using <a href="http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/namespace_esri.htm#request">esri.request</a>. </div> </div>
// get print templates from the export web map task var printInfo = esri.request({ "url": printURL, "content": { "f": "json" } }); printInfo.then(handlePrintInfo, handleError); function handlePrintInfo(resp) { var layoutTemplate, templateNames, mapOnlyIndex, templates; layoutTemplate = dojo.filter(resp.parameters, function(param, idx) { return param.name === "Layout_Template"; }); if ( layoutTemplate.length == 0 ) { console.log("print service parameters name for templates must be \"Layout_Template\""); return; } templateNames = layoutTemplate[0].choiceList; // remove the MAP_ONLY template then add it to the end of the list of templates mapOnlyIndex = dojo.indexOf(templateNames, "MAP_ONLY"); if ( mapOnlyIndex > -1 ) { var mapOnly = templateNames.splice(mapOnlyIndex, mapOnlyIndex + 1)[0]; templateNames.push(mapOnly); } // create a print template for each choice templates = dojo.map(templateNames, function(ch) { var plate = new esri.tasks.PrintTemplate(); plate.layout = plate.label = ch; plate.format = "PDF"; plate.layoutOptions = { "authorText": "Made by: Marion County Information Technology", "copyrightText": "Maps are for display purposes only", "legendLayers": [], "titleText": "Marion County Parks", "scalebarUnit": "Miles" }; return plate; }); // create the print dijit var printer = new esri.dijit.Print({ "map": map, "templates": templates, url: printURL }, dojo.byId("print_button")); printer.startup(); } function handleError(err) { alert(err); console.log("Something broke: ", err); } }
<td align="center" style="width: 40px;" valign="middle"> <button dojotype="dijit.form.ToggleButton" id="imgprint" title="Print Map" onclick="window.print();"> <img style="border:none;" src="images/print.png" alt="Print Map"/> </td>
