I have 5 geodatabases with identical data but of different areas. I am trying to append data from all five to one new geodatabase. There are about 50 feature classes in each geodatabase so I am looking for a script to automate the process.
I need the Appending multiple Geodatabases into one tool for my won desktop GIS 10.8.1.
How to download this tool for free?
Please see the following video and tool Append Multiple Geodatabase - YouTube
Hi Ian.
I have a code snippet that you can use, To use it Replace the <outputGDB> and <InputGDB1><InputGDB2><InputGDBN> values.
WARNING: It's tested with GDB with the exactly same schema in all GDBs.
import arcpy from arcpy import env ##Destination GDB GDBD="<output GDB>" ##List of Origin GDB GDBS=["<inputGDB1>","<inputGDB2>","...","<inputGDBN>"] ##Set Environment arcpy.env.workspace=GDBD ##Get List of FDS FDS=arcpy.ListDatasets() ##Get List of Root Feature Classes ROOTFCS=arcpy.ListFeatureClasses() ##Append elements in Root Feature Classes for fcr in ROOTFCS: appendinput=[] for FCI in GDBS: appendinput.append(FCI+"/"+fcr) ##print appendinput arcpy.Append_management(appendinput,GDBD+'/'+fcr,"TEST") ##Append elements of Feature Classes inside Feature Datasets for FD in FDS: for FC in arcpy.ListFeatureClasses("*","",FD): appendinput2=[] for FCI2 in GDBS: appendinput2.append(FCI2+"/"+FC) ##print appendinput2 arcpy.Append_management(appendinput2,GDBD+'/'+FC,"TEST")
