Hi I am new to linear referencing but have got a route layer and an Access database that will house the tables. I have created an OLE connection to the Access database and can make route events from the tables in Access without any problems. However what I need is to make it possible for field crews to update the tables in Access and have those changes automatically updated in the route event layer without having to constantly go in and recreate it. Does anyone know if this is even possible? Any help would be much appreciated. Thanks,
Richard,
While I had the same issue with events from a filebased GDB, I tried your suggestion, reloading lyr files within ArcObjects, but without success. I also tried to re-create the RouteEventSourceName for the layers and do a IDataLayer2.Disconnect/Connect, nothing worked. The cache seems to be clever enough to understand that I'm still referencing the same event table, but too stupid to refresh itself.
What finally helped me out was setting the DWORD decimal value of HKEY_CURRENT_USER\Software\ESRI\ArcMap\DynSeg\UseOptimization to 0 in the registry as described in 34350 - How are updates to event layers handled in ArcGIS Server? . Maybe this helps if anyone else is looking for a solution to the same problem here.
Fridjof
