Hello,The GPS Status Bar contains a lot of useful information.The values you have indicated in your question are the altitude (m) and speed (kmph) of your GPS position.[ATTACH=CONFIG]30438[/ATTACH]The GPS Status Bar also indicates the number of satellites that are being used as well as the number of satellites in view with the GPS skyplot.[ATTACH=CONFIG]30439[/ATTACH]You can also see the signal strength of the satellites and the PDOP value. PDOP stands for Positional Dilution of Precision and is a value between 0-99 to indicate positional accuracy (the lower the number, the more accurate the position). Mapping grade projects usually require a PDOP of 6.0 or less, with survey grade projects requiring a PDOP of 4.0 or less.[ATTACH=CONFIG]30440[/ATTACH] See here for more information on GPS dilution of precision, including how PDOP is calculated.Hope this helps,Hannah 🙂
