Hi, Looking forward to talking to authors at the UC too. There will be a story maps booth at the Esri Showcase area of the exhibition at the UC. There are also several story maps sessions and demos.Those marker symbols should be working: they are part of the shortlist download. I suspect something else is preventing your layers from drawing correctly.
I had a look at your web map:http://www.arcgis.com/home/webmap/viewer.html?webmap=98cb3b8fdca64f4786a0821dac137a86 and your Shortlist isn't working because the Number field for the points of interest isn't populated: it is 0 for each feature. They need to be numbered 1 thru xyz because that is the number used in the SHortlist for each place. If that value is 0 for each feature it's not going to work. That is why the marker symbols are not drawing on the map. http://storymaps.esri.com/templates/shortlist/?webmap=98cb3b8fdca64f4786a0821dac137a86
Thank you! I'm going to update the fields now and give that a shot! I'll reply sometime this afternoon with a resolution update! Thank you very much for the advice!
