I have kmz's that I would like to overlay in Arcmap for comparison to our data but I don't want to convert it.
well...
<SPAN class="string token">""" Script: kmz_kml.py Author: <A class="jive-link-email-small" href="mailto:Dan.Patterson@carleton.ca" rel="nofollow noopener noreferrer" target="_blank">Dan.Patterson@carleton.ca</A> References: many Purpose: convert kmz to kml base script """</SPAN> <SPAN class="keyword token">import</SPAN> zipfile <SPAN class="keyword token">from</SPAN> xml<SPAN class="punctuation token">.</SPAN>dom <SPAN class="keyword token">import</SPAN> minidom <SPAN class="keyword token">def</SPAN> <SPAN class="token function">kmz_to_kml</SPAN><SPAN class="punctuation token">(</SPAN>fname<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"""save kmz to kml"""</SPAN> zf <SPAN class="operator token">=</SPAN> zipfile<SPAN class="punctuation token">.</SPAN>ZipFile<SPAN class="punctuation token">(</SPAN>fname<SPAN class="punctuation token">,</SPAN><SPAN class="string token">'r'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">for</SPAN> fn <SPAN class="keyword token">in</SPAN> zf<SPAN class="punctuation token">.</SPAN>namelist<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">if</SPAN> fn<SPAN class="punctuation token">.</SPAN>endswith<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'.kml'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> content <SPAN class="operator token">=</SPAN> zf<SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN>fn<SPAN class="punctuation token">)</SPAN> xmldoc <SPAN class="operator token">=</SPAN> minidom<SPAN class="punctuation token">.</SPAN>parseString<SPAN class="punctuation token">(</SPAN>content<SPAN class="punctuation token">)</SPAN> out_name <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>fname<SPAN class="punctuation token">.</SPAN>replace<SPAN class="punctuation token">(</SPAN><SPAN class="string token">".kmz"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">".kml"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>replace<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"\\"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"/"</SPAN><SPAN class="punctuation token">)</SPAN> out <SPAN class="operator token">=</SPAN> open<SPAN class="punctuation token">(</SPAN>out_name<SPAN class="punctuation token">,</SPAN><SPAN class="string token">'w'</SPAN><SPAN class="punctuation token">)</SPAN> out<SPAN class="punctuation token">.</SPAN>writelines<SPAN class="punctuation token">(</SPAN>xmldoc<SPAN class="punctuation token">.</SPAN>toxml<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> out<SPAN class="punctuation token">.</SPAN>close<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"no kml file"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">if</SPAN> __name__ <SPAN class="operator token">==</SPAN> <SPAN class="string token">"__main__"</SPAN><SPAN class="punctuation token">:</SPAN> fname <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"Your_folder_here\GIS_central.kmz"</SPAN> kmz_to_kml<SPAN class="punctuation token">(</SPAN>fname<SPAN class="punctuation token">)</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
found it. which could obviously be cleverly modified for batch production
kmz files are zipped kml files ... some backgrounders that are useful
Can I convert a kmz file to kml? - Geographic Information Systems Stack Exchange
provides some help and with the aid of python modules:
one can even process things directly, for example
Calculate distance from .kmz files « Python recipes « ActiveState Code
And there are many other examples out there.
You might be right, Chris. The supported formats lists "OpenGIS KML Encoding Standard" although I don't know if that includes all KML, or any KMZ.
I think you can natively with ArcGIS Data Interoperability (ArcGIS Data Interoperability | Overview).
David,
Like Darren said, you will need to convert it.
Use this tool:
KML To Layer—Help | ArcGIS for Desktop
Make edits, then use the opposite tool to change it back:
Layer To KML—Help | ArcGIS for Desktop
There is no way to view KMZ in ArcMap without converting it.
