Jamal,We intentionally dissolve the pixel boundaries (for continuous pixel values) so the output is not so large. This is also why we do not allow you to convert float rasters to polygons. You could potentially end up with billions of polygon records depending on the size of your raster. I would suggest using the Create Fishnet tool that is part of core ArcGIS Desktop. It might take a long time to process if you are going to be creating a lot of cells.If you need to have the raster value associated with the fishnet polygons, convert your raster to points and do a spatial join.Regards,Eric
Use the following 3 GP toolsCreate Fishnet- extent = raster extent- cell size width/height = raster cell size- number of rows/columns = number of rows/columns of raster- Geometry type = PolylineRaster To PointFeature To Polygon- Input features = Fishnet output- Label Features = Raster To Point output
