Hi folks,I am wondering what type of exporter should I use to export tables (as standalonetable) to get file.txt There is a lot of exporter to export into jpeg, tiff etc... and there is a possibility to select txt format in the Exportdialog. Unfortunately I do not find any solution to write a macro with VB to create a txt file of the attribute table ...Cheersand thank youL.
Dim CSVFile As System.IO.StreamWriter CSVFile = New System.IO.StreamWriter("C:\FileNameToCreate.txt") Dim sb As New System.Text.StringBuilder sb = New System.Text.StringBuilder CSVFile.WriteLine("Field1, Field2, Field3, Field4, Field5") Using CSVFile For Each r As DataRow In theADONetDataSet.Tables(0).Rows sb = New System.Text.StringBuilder sb.Append((r("Field1")) & "," _ & (r("Field2")) & "," _ & (r("Field3") & "," _ & (r("Field4")) & "," _ & (r("Field5")))) CSVFile.WriteLine(sb.ToString) Next End Using
