We are working on a Custom Widget.
How do I clear the "Search Widget" (Green) from a Custom widget(Red).
Attaching a snap.
I tried this code.
Muralidhar,
You will need to get a reference to the search widget from your widget. for that you will need add 'jimu/WidgetManager', to your widgets define array.
Then add this new helper function:
_getWidgetConfig<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>widgetName<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> widgetCnfg <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN> arrayUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">some</SPAN><SPAN class="punctuation token">(</SPAN>WidgetManager<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getInstance</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>appConfig<SPAN class="punctuation token">.</SPAN>widgetPool<SPAN class="punctuation token">.</SPAN>widgets<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>aWidget<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>aWidget<SPAN class="punctuation token">.</SPAN>name <SPAN class="operator token">==</SPAN> widgetName<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> widgetCnfg <SPAN class="operator token">=</SPAN> aWidget<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">return</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">return</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>widgetCnfg<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">/*Check OnScreen widgets if not found in widgetPool*/</SPAN> arrayUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">some</SPAN><SPAN class="punctuation token">(</SPAN>WidgetManager<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getInstance</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>appConfig<SPAN class="punctuation token">.</SPAN>widgetOnScreen<SPAN class="punctuation token">.</SPAN>widgets<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>aWidget<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>aWidget<SPAN class="punctuation token">.</SPAN>name <SPAN class="operator token">==</SPAN> widgetName<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> widgetCnfg <SPAN class="operator token">=</SPAN> aWidget<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">return</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">return</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">return</SPAN> widgetCnfg<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
And call this code:
<SPAN class="keyword token">var</SPAN> widgetCfg <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">_getWidgetConfig</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'Search'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>widgetCfg<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> searchWidget <SPAN class="operator token">=</SPAN> WidgetManager<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getInstance</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">getWidgetByLabel</SPAN><SPAN class="punctuation token">(</SPAN>widgetCfg<SPAN class="punctuation token">.</SPAN>label<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>searchWidget<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> searchWidget<SPAN class="punctuation token">.</SPAN>searchDijit<SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">set</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"value"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thank you so much. This code worked perfectly.
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
