Error: “Packaging succeeded, but publishing failed”,
I couldn’t figure out why I’m getting the error below
What might be the issue here?
Thank you
Best
Jamal
Visit your task manager and see how many SOC processes you are running, these are map services, if your server is hosed down with these processes it might affect your publishing tasks.
Is your data registered with the server?
It would help if you provided pertinent information on:
You should always review every initial post and ask yourself, "If a complete stranger who knows nothing about my deployment were to see this, is there enough information that they would be able to help me?" If you have doubts about what might be required, see my blog on this topic.
- V
Many thanks Vince for the help,
However, I have just stopped and started the ArcGIS Server service and it works fine now.
What were the contents of the Results window?
Thanks Dan,
Here you go the content of the “result” window.
The publishing tools were ON.
Hi Dan,
I’m newly getting the same error
Please, have a look on the “Result” window
the error link says check the server logs. Note, all error messages are listed in this link
As usual, the logs provide very general feedback. However, I did the same (stop\restart the service) and it worked fine now
But why this issue persists to exist?
Hi Jamal,
I've seen similar behavior after updating or changing the ArcGIS Server account using the Configure ArcGIS Server account utility. Like you've discovered, I had to manually start/stop the ArcGIS Server local service in order to successfully publish services, but I haven't had to continually stop/start the local service. Did you update or change your ArcGIS Server account?
I would try changing your log filter level to Verbose to see if additional information is logged when you attempt to publish a service. However, you will want to change it back to Warning since the Verbose level can bloat the size of your log files.
I hope this helps.
Many thanks Andy,
All what I did is that I have changed the credential of the ArcGIS Server Manager but not the ArcGIS Server Account.
Since that time, I got the error message two times. I’ll see if it continues to appear as I publish.
Have you checked if the account used by your ArcGIS server windows service has access to "c:\arcgiserver" folder?
Thanks Swapna,
Sure. the “ArcGIS Server” account is the owner.
What other issues should I consider?
Sometimes map documents may become corrupt. Have you tried to re-create your .MXD?
I have created tens of new mxd files but the problem persists to exist
What is confusing me the most is:
Any other suggestions?
Are you maxing out your resources (ram/cpu) on the ArcGIS Server machine? To check these, start the Task Manager and click the performance tab. Also what are your system specs: OS, Ram, etc..?
Many thanks guys for the help,
I have a similar problem. I try to publish a service, I get the same error shown above. Then I stop a service already running on that server, and I can successfully publish the service, then restart the one I sacrificed.
My question is: how much memory do the publishing tools require? Is there a mechanism which AGServer uses to detect available memory and then "decide" whether or not to publish, and if so, what is the threshold?
Very interesting question Marianne. Hope experts can provide an answer.
you can check the hardware resources usage from windows task manager of the server. You can also install splunk on the server which monitors and keeps the history of memory/CPU usage
Many thanks Sapna,
Our query here is related to the quota of the ArcSoc.exe on the server as this is controlled by the number of cores available on it.
Notes:
1 core on the server can take up to 5 ArcSoc.exe.
1 core needs 3 GB
Now:
Each map service will consume a number of ArcSoc.exe. The total consumed ArcSoc.exe shouldn’t exceed #of cores*5
There should be an indicator to show the remaining number of ArcSoc.exe before proceeding in publishing.
What do you think?
ESRI has released new patch for this issue 10.3, just download and install
click link below
ArcGIS 10.3 for Server Site Creation Failure and Service Startup Performance Patch | Samples and Utilities
We are having the exact same issue at 10.2.2! If we reboot the server and then publish it works, if the number of SOC processes increase and the server is under load it fails. This seems a bit ridiculous given at version 10sp5 we had twice the number of SOC processes and half the server!! Would love to discuss further. When calling ESRI, they do not have an answer and despite the CPU at 15% and RAM at less than 50% it still fails. This is an application issue and it needs to be fixed. Version 10sp5 was much more stable. My email is akreag at bisconsultants dot com.
As a follow up. We fixed this issue. After confirming that physical resources were not under stress, we set min process to 1 and max to 13, also went and adjusted the windows virtual memory to best and system managed. This did the trick. Contact me if you would like to discuss.
Thank you very much guys for the help
Then I have two solutions here:
You have a 16 core server so optimal setting for the min is 1 and max is 17 (cores plus 1).
Virtual memory setting is good.
You may also want to check under the arcgis server admin, edit, adjust your soc process HEAP to double the current setting.
Aaron
Thank you Aaron Kreag for the prompt help,
How to approach the “heap” option?
